Group: DynoMotion Message: 525 From: bouseman_73 Date: 7/26/2010
Subject: KFlop and Yaskawa motors
Hi
I have Yaskawa SGMAH motor with incremental encoder and Servopack SGDH amplifier. What is the best wiring to connect yaskawa amplifer and KFlop.
thanks
Group: DynoMotion Message: 526 From: Tom Kerekes Date: 7/26/2010
Subject: Re: KFlop and Yaskawa motors
I googled and found this:
It looks like you basically have 2 options.
#1 - Let the Amplifier close the servo loop and just send Step + Direction to the Amplifier
see page 3-31
#2 - Close the Position loop with KFlop+Kanalog
see page 3-32
Group: DynoMotion Message: 530 From: Jack Date: 7/27/2010
Tom
Is it also possible to use speed control with the Yaskawa & KFlop?
Speed control seems to be the best choice for cnc applications.
Past discussion on this at the CNCZone.
Link:
http://www.cnczone.com/forums/showthread.php?t=39761&page=2
Jack
"It looks like you basically have 2 options."
Group: DynoMotion Message: 532 From: Tom Kerekes Date: 7/27/2010
Hi Jack,
Yes speed (velocity) control would be the preferred option.  You would need our KFlop+Kanalog board to output a +/- 10V analog signal to command the velocity to the drive.  The drive would be configured to drive the motor (and load) at the speed it is commanded by the Vref input.  You can test by applying a small voltage (ie 1.5V battery) to the Vref input.  The motor should drive at 15% full speed.  If you reverse the battery, the motor direction should reverse.
The differential encoder signals from the drive would be connected to Kanalog so that KFlop can close the position feedback loop.  With only simple Proportional Gain, KFlop will command a velocity proportional to the error (distance to target position).  So basically the motor will be commanded to go slower and slower as it gets closer and closer which results in an exponential curve.
Group: DynoMotion Message: 536 From: Jack Date: 7/27/2010
Tom
Thanks for the quick reply.
Seems like there is a lot of interest using the Yaskawa drives and motors with your products.
Jack
> Hi Jack,
Group: DynoMotion Message: 537 From: Jack Date: 7/27/2010
One more question.
Do you think this solution will handle Gcode that has thousands of short moves/line segments? Often this type of code can cause jerky movements with the cutter/spindle.
Jack
Group: DynoMotion Message: 538 From: bouseman_73 Date: 7/27/2010
Tom, thanks for your answer
But a have questions more...
1) Yaskawa servopack drive is using for control speed range +/- 2-10v (not 0-10v) . How can I setup KMotion for it?
2) And Servopack has A, B, C phase encoder output (for incremental), but KAnalog has A\B input signals only. What about C signal?
3) And what is the wiring for limit switch
thank you in advance
Slava
Group: DynoMotion Message: 539 From: Tom Kerekes Date: 7/27/2010
Hi Jack,
I think that has little to do with the drive or Step/Dir vs Analog control.  That is more related to the G code interpreter and Trajectory Planner.  I think KFlop does well compared to other systems.  It can accept a minimum of 500 motion segments/second.  A machine can't usually change direction that fast.  I think our KMotionCNC handles small vectors better than Mach3.
Group: DynoMotion Message: 540 From: Tom Kerekes Date: 7/27/2010
Hi Slava,
Regarding:
#1 - I think that means they can accept a range from -2V to +2V or a range from -10V to +10V, probably configurable in the Yaskawa settings.  You could use the -2V to +2V range by limiting the Max Output on Kanalog.  It would still work, but you would have a bit less resolution on the velocity command about +/- 400 DAC counts instead of +/- 2047 DAC counts.  I would recommend setting the Yaskawa to use a +/- 10V range.
#2 - The C signal is a index pulse that occurs once per motor rev.  It isn't usually needed.  It can be helpful for homing very accurately, but you still need a home switch since the index happens every rev so without the switch you wouldn't know what rev you were at.  Homing and such is performed in software by using a KFlop User Program written in C.  This is very flexible and can handle many homing techniques but does require you to write or adapt an existing homing program.  So for example your homing process may be something like: jog a medium speed until the home switch is detected, then keep moving at slow speed until the index pulse is detected, then stop.  The C signal can be connected to any of the unused 16 A or B differential input pairs.
#3 - Limit switches are also configurable for any spare input.  Kanalog provides 8 opto isolated inputs that can be directly connected to 5 to 24V signals.
Group: DynoMotion Message: 610 From: amir Date: 8/26/2010
i have Panasonic Servo Drive model:ADKA100GVTAAA(100W) and ADKA400GVT(400W) .and all are analog. only speed command.
they are very old( about 20 years ) and made with Yaskawa company.
Their appearance is exactly like Yaskawa.
i run them with Dc voltage from 0~10 V,and all thing is ok.
Whether i can use Kflop and kanalog ?
Amir
Group: DynoMotion Message: 612 From: Tom Kerekes Date: 8/26/2010
Hi Amir,
That should work.  You must have encoder signals as well, preferably differential signals
Group: DynoMotion Message: 613 From: amir piry Date: 8/26/2010
thx Tom
please see my schematic and wiring:
http://i33.tinypic.com/adchls.jpg
i have a problem with this driver ,when i set "speed command" to 0V ,motor was Motionless but not locked , in practice i can turn shaft with hand.
are you can help me?
Amir
--- On Thu, 8/26/10, Tom Kerekes <tk@...> wrote:
Subject: Re: [DynoMotion] Re: KFlop and Yaskawa motors
Date: Thursday, August 26, 2010, 8:00 PM
Hi Amir,
Group: DynoMotion Message: 614 From: Tom Kerekes Date: 8/26/2010
Amir,
Do your motors have tachometers or encoders connected to the drive?
Normally if you command 0V to the speed command input to an amplifier with tachometer feedback the drive will attempt to maintain at 0 speed.  The motor will NOT be "locked" (servo'ed) to a position.  Encoder Position feedback is needed to do this.  With just tachometer feedback the motor should feel hard to turn like there is a lot of friction (viscus).  The faster you try to turn the motor the harder it should be to turn.
I hope this helps
Group: DynoMotion Message: 615 From: amir piry Date: 8/26/2010
thx, very good explain.
with regard to your comments, i think is tachometer feedback.
please see my motor and schematic :
http://i38.tinypic.com/xzk7d.jpg
http://i36.tinypic.com/svm35y.jpg
I'm disappointed for using them.
However,can i run them with kflop\kanalog ?
Amir
Date: Thursday, August 26, 2010, 11:52 PM
Amir,
I hope this helps
Group: DynoMotion Message: 616 From: Tom Kerekes Date: 8/26/2010
Hi Amir,
Those appear to be 3 phase brushless motors with encoders.  The schematic notes 1000ppr (4000 counts/rev).   You will need to determine the encoder signals.  I see there are 14 encoder wires.  Probably 6 differential signal pairs plus power and ground.  The 6 encoder signals are probably 3 signals used by the drive to do the motor commutation.  The other 3 are probably A, B, and Index signals.  You would need to find the A B differential signals (4 wires) and connect them to Kanalog (in parallel with the existing connections to the drive).  If you have an oscilloscope it would be easy to determine.  Otherwise trial and error would work.  It should all be possible.
Group: DynoMotion Message: 619 From: amir piry Date: 8/27/2010
Hi Tom
thx for support.
you say :"The motor will NOT be "locked" (servo'ed) to a position" and will attempt to maintain at 0 speed.
my question :
Whether in this type of motors ,If the pressure load axis was high. will not cause Rotate the shaft motor  ?
I hope you understand what I mean.
Amir
Amir,
I hope this helps
Group: DynoMotion Message: 620 From: Tom Kerekes Date: 8/27/2010
Hi Amir,
No it has nothing to do with the type of motor.  All motors will work this way.  They need encoder feedback such that the servo loop will increase the torque to whatever is necessary (within limits) to move to or hold the comanded position.
Group: DynoMotion Message: 625 From: amir piry Date: 8/31/2010
Hi Tom
thx for very good support.
I will use kflop/kanalog for plasma machine(with mach3 software) .
There is no limit to it?
Can I use the THC?
I do research about smoothstepper .
With some restrictions, including THC and backlash
Amir
Group: DynoMotion Message: 626 From: Tom Kerekes Date: 8/31/2010
Hi Amir,
Well I don't know what THCdoes in Mach3 (Torch Height Control ?)  Is it documented somewhere?  What do you need it to do exactly?
I think such things are possible.  One user with a CO2 laser system developed a Z focus control.  Basically the Z axis had two modes.
#1 was normal where the Z axis servoed to an absolute height based on encoder position.
#2 was a dual position loop where the Z axis servo was commanded to follow an analog LVDT (height sensor) so Z would track some relative height above the stock.
M codes were used to switch modes. I think it worked well.
After many many requests for backlash compensation we finally added it a couple months ago.  To my knowledge no one has tried it :}
Group: DynoMotion Message: 627 From: amir piry Date: 8/31/2010
Hi Tom
link about THC :http://www.centricut.com/New_Lessons/lessons_10.html
in fact, with sensor board (thc) we can measure voltage between nozzle and plate ,and then Z axis change to Maintain constant height.
thx for all things
Amir
Date: Tuesday, August 31, 2010, 9:46 PM
Hi Amir,
